I've bought a Pentax K Mount lens (28mm) and since I haven't yet an adapter ring pk-mount -> m4/3, I've tried to use directly on my gh1 with an adaptor FD-m4/3. Of course, the adaptor doesn't fit correctly but..if you watch the result just holding the lens attached to the ring,you will able to focus and...you will get a remarkable WIDER FoV than 50mm eq (28x1.8 on gh1)!!! Anyone could explain me the reason?
I think I will modify directly a fd adapter! ;) the Fov seems to me close to 30mm (so the lens performs as a 18mm 2.8). Quite good wide open, but it's impossible to focus at 0,5 m. perfect for interior scene...and it's damned cheap!
your focus marks will be off, so if you go by those, that could be an issue, but as far as I know, if would be the opposite of a macro ring. Really wish I had a 3D printer right about now so that I could make some adapters and see how everything works through trial and error
thanks @balazer, it could be a ghetto-trick to get a cheap fast wide lens ;) what are the main drawbacks however? it will be more difficult to focus close subjects, but at the same time it should be easier to achieve a "deep focus" look...is it?
Putting the lens closer to the camera makes the image circle smaller and reduces the focal length. It also shifts the focus range away.
