GH2 hack - where in menu do I switch between PAL and NTSC?
  • So maybe I am just dumb, but i cant find a menu entry to switch between PAL and NTSC after I hacked it...
    Can anybody tell my where I find this in the menu?
    thanks a lot,
    paralion
  • 3 Replies sorted by
  • Look at setting and set tv output standard to one you like, it'll also force change to your video.
  • If i'm correct this only works with an empty SD card.
  • @AmandaNL
    You are not correct.
    It work any way.
    But you can't record both PAL and NTSC on same card.
    So, either reformat it, or use other card.
