GH2 High Quality GOP3 Settings, Series 2: 'AN' Valkyrie, GOLGOP3-13, GOP3ZILLA, Duke, natural :-)
  • 670 Replies sorted by
  • I come back to work with my GH2 and golgop3 max2, I'm very happy, the result is wonderfull, definition, stable, it spans with my 32Go/45Mbits (same 64Mbits of the frame limit), the great shadows, i'm sure I keep it. I used to canon fd 50mm and 28mm, and the slrmagic 12mm and it's very nice. Thnak you thank you
  • man i gotto try me some golgop3.. @surfculture, would you mind telling us what made you decide to keep this setting?
  • @surfculture Thank YOU for kind words! :-)
  • @bkmcwd I've tried golgop3 max2 and I keep it, it's nice, very nice, this afternoon I work with my GH2 and you hack golgop 3 max2. Thank you so much.
  • @abraham1307 Many thanks for testing, mate! :-)
    Is this sample from HBR? Looks nice.
  • This is a mix of Bkmcwd Valkyrie settings ranging from Valkyrie 444 1.5b-1.5e and Valkyrie Cinema Smooth.
  • Thank you, I go to try golgop3 and I'll say you
  • @surfculture Hi,
    First of all, you should try GOLGOP3-13-A2 or MAX2 BETA4. And probably, Valkyrie 444 TZ2 C1.5e should be tried next.
    Priority is given to being used without changing original 444 matrix of Chris as much as possible in Valkyrie 444 TZ2s. Since 444 matrix has very peaky character, in order to make it stabilized, the quite safe bit rate must be used in HBR. If these situations are taken into consideration, the frame limit of C1.5e is by no means too low.
    Valkyrie 444 TZ2 C1.5d and Cinema Smooth are still somewhat unstable compared with GOLGOP3-13_BETA4s or C1.5e.
    If you use only 24p, it is possible to use any setting.
    Many thanks for feedbacks from you. :-)
  • because I try valkyrie c1.5e but i found that the lowness of the frame limit down any. thanks again
  • Hello,
    What is it the better golgop3 12 A2 beta4, valkyrie tz2 c1.5e or 1.5d or valkyrie cinema smooth? I work with canon fd and slrmagic 12mm ans I would like absolut stability, don't span and a wonderfull cinematographic picture ? and all that in all mode avchd .
    Thank you.
  • I am working on following Valkyrie Cinema Smooth TZ2 now. I look for those who test the test version of this again. Please send PM. Many thanks! :-)
  • @tonalt
    Any chance that GOLGOP3-13-A2_BETA4 would work with Sandisk 30MB/s without freezing?
    Although I did not test with 30MB/s card, I think that it is satisfactory in almost all cases. And I know the users who are using with 30MB/s. However, since it is not perfect, please test beforehand. :-)
  • Any chance that GOLGOP3-13-A2_BETA4 would work with Sandisk 30MB/s without freezing?
  • @har_k Thanks for comment! :-) Although this C1.5e is probably most stable in Valkyries, I am worried about the lowness of the frame limit. I am going to test more.
  • @bkmcwd
    If I had to say, I think C1.5d is better in image quality. But It is a very slight difference.
    As far as I tried, reliability was the same both.
    It is difficult choice.:-)
  • @har_k Thanks for using Valkyrie 444 TZ2! :-)
    It looks very nice. Do you think that which of C1.5d and C1.5e is better in HBR?
  • @bkmcwd
    I used "Valkyrie 444 TYPE-ZERO2_Candidate1.5e" HBR(30p) mode.
    Thanks for amazing quality settings and your hard work!!
    *FILM MODE is NOS.(-2,0,+1,-2) and the lens is LUMIX G X VARIO 12-35mm / LUMIX G X VARIO PZ 45-175mm
    *SANDISK Extreme Pro SDXC UHS-I (95MB/s) 64GB
  • @Vitaliy_Kiselev OK, I am sure. However, in case there is the same misapprehension as other users, I think that this affair should be open.
  • @tusoli5
    @bkmcwd
    Please do not turn topic into chat. Use PM if required.
  • @tusoli5 I also did the spanning test with SanDisk 95MB/s SDXC again. Although all stress was given and tested, about spanning, spanning was possible for any number of times satisfactorily at all.
    24H of Valkyrie uses the highest bit rate in my settings. For the moment, if it is not 95MB/s SDXC, I cannot say that spanning is possible. Thanks. :-)
    *EDIT: Sorry! This is not 3 times but 2 times spaned sample.
    1297 x 635 - 608K
  • @tusoli5 Thanks for report! :-)
    sdhc 95m/s...
    I assume that it can be used satisfactorily on only "95 MB/s SDXC." Although I am imagining that it is the cause which you used on SDHC, I also check again.
  • I will test back the Golgop3-13-Max and let you know.
  • It works fine with the others modes, only doesn't span in 24i/s mode.
  • DIdn't have this problem with Golgop3-13-A2_Beta4
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
