MagAO O.I.S for cosmos scanning
  • gmt home page
    "We can, for the first time, make long-exposure images that resolve objects just 0.02 arcseconds across – the equivalent of a dime viewed from more than a hundred miles away. At that resolution, you could see a baseball diamond on the moon."
    The twofold improvement over past efforts rests on the fact that for the first time, a telescope with a large diameter primary mirror is being used for digital photography at its theoretical resolution limit in visible wavelengths – light that the human eye can see.
    "As we move towards shorter wavelengths, image sharpness improves," said Jared Males, a NASA Sagan Fellow at the UA's department of astronomy. "Until now, large telescopes could make the theoretically sharpest photos only in infrared – or long wavelength – light, but our new camera can take photos that are twice as sharp in the visible light spectrum."
    To overcome atmospheric turbulence, which plagues earth-based telescopes by causing the image to blur, Close's team developed a very powerful adaptive optics system that floats a thin (1/16th of an inch) curved glass mirror (2.8 feet across) on a magnetic field 30 feet above the telescope's primary mirror.
    This so-called Adaptive Secondary Mirror (ASM) can change its shape at 585 points on its surface 1,000 times each second, counteracting the blurring effects of the atmosphere.
    The new adaptive optics system, called MagAO for "Magellan Adaptive Optics," has already made some important scientific discoveries, published today in three scientific papers in the Astrophysical Journal. As the system was being tested and received what astronomers call "first light," the team pointed it to a famous and well-studied massive star that gives the Great Orion Nebula (Object M42) most of its UV light. The Orion Nebula, located just below Orion's Belt visible as smudge of light even with regular binoculars.
    You can read whole article at phys.org
    gashô
