IDOLCAM - Pocket 4K Vlogging camera
    https://www.idolcam.co
    Specs:
    3 axis Gimbal: A mini 3 axis gimbal with close-loop sensors and motors that stabilize the lens to achieve stable video.
    Magnetic Interchangeable Lens: One of the kind lens mounting system leveraging the readily available M12 lens from the action camera and security camera industry. Making lens changes a snap!
    Magnetic Interchangeable Ring light: Even lighting to fill in shadow on user's face. Making lighting changes a snap!
    Magnetic Interchangeable Animal spot light: Mysterious mood lighting on the subject, providing lighting on the central area of the frame only.
    180 Rotational Touchscreen: Preview for selfie shots and video recording when looking down. Also allow quick navigation toreview video and change settings.
    Moving TimeLapse: Dynamic Time-lapse without the need for additional motorized time-lapse head.
    Remote Framing: Allow users to control the angle of the lens with our App through the smartphone. User will be able to preview video and snap the perfect selfies and self narrative video remotely and no longer limited by the arms length.
    Frame Rates: 4K/30fps, 4K/25fps, 2.7K/30fps, 2.5K/60fps, 2.5K/30fps, 1080/120fps, 1080/60fps, 1080/30fps, 720/240fps (24fps in development)
    Mic Port: Connect to external mic to get high audio quality.
    RC control and Drone Port: Extension to more application such as drones and filming remotely.
    APP: Preview of images and video and ability to control the aim of the lens remotely (in development)
    4th Axis: A mechanical spring device that reduce in vertical movement from walking, jogging that all 3 axis gimbal can not completely compensate. It can also serve as a handle. (Optional)
    Battery Grip: This serve as a handle and provides additional power for a full day operation and can also charge smartphones too. (Optional)
    1000 x 525 - 76K
    1100 x 565 - 91K
    600 x 315 - 36K
    550 x 283 - 42K
    770 x 396 - 71K
    880 x 452 - 83K
  • 5 Replies sorted by
  • Testing out the Idolcam! Blogging camera
  • For me latest Insta360 camera is much better blogging camera, as you can frame in post also :-)
  • This design looks like an industrial security camera, not a sleek consumer product, maybe put it inside a crystal ball :)
  • Seems like they got existing 3 axis gimbal (exactly such form is available) and added other parts including camera.
    But as I said, can't compare with Insta360, as they have slick product.
  • This seems like, at best, a budget competitor for the Osmo+. You can't change lenses on the Osmo, but it has a zoom (24-70ish, I think). Also, the Osmo uses a standard filter thread so ND's are not too expensive. Plus, for some of the jib type of shots that they are hyping in their video, you can buy a third-party extension arm for Osmo that lets you maintain control of the camera.
