Wide Conversion Lens DMW-GWC1, Tele Conversion Lens DMW-GTC1
            Macro Conversion Lens DMW-GMC1 and Fisheye Conversion Lens DMW-GFC1
Panasonic is pleased to introduce a variety of conversion lenses for the Interchangeable Lens System Camera LUMIX G Micro System. Compact, lightweight conversion lenses propose users to experience the fun of switching lens and enjoy the different angle of view casually.
| Compatibility* | Wide Conversion Lens DMW-GWC1 | Tele Conversion Lens DMW-GTC1 | Macro Conversion Lens DMW-GMC1 | Fisheye Conversion Lens DMW-GFC1 |
| H-PS14042 |  |  |  |  |
| H-H014 |  | - |  |  |
Attachable to H-PS14042 and H-H014*As of January 9, 2012.
Attachable to H-PS14042*As of January 9, 2012.
* Attachable when the lens is at tele-end.
* Closest focusing distance is 0.14m with H-H014 and 0.16m with H-PS14042. Longest Focusing Distance is 0.23m with H-H014 and 0.26m with H-PS14042.
                  how many f stops do we gain with this adapters?
Guess its more loosing than gaining f stops.. however. Depending on the quality of the lense (sharpness, barrel distortion, aberation..) the wide conversion together with 14 mm pancake might become a nice affordable combo.
Maybe with these converters new camera firmware will come with extra option for converters....?
DWS-07ML was announced around the same time. It has two different versions for 37mm and 49mm threads. It claims 0.7x.
DMW-GWC1 seems supporting both 37mm and 46mm threads. It’s 0.79x and seems twice more expensive than the other one.
Anyone with more info?
I went ahead and ordered the DMW-GWC1 to use with the 14mm lens. I'm sure the adapter will loose a little light from f2.5 - but it should still be faster than the 7-14mm (f4).
For what it's worth, I usually found my 7-14mm lens at ~10-11mm setting, so the DMW-GWC1 should fit my needs well.
DWS-07ML has 50cm min focus distance where DMW-GWC1 has 17cm.
I can't see why DMW-GWC1 can't be used on other m43 lenses.
14mm 2.5 -> 11mm ??
25mm 1.4 -> 20mm ??
45mm 1.8 -> 35mm ??
Is it possible to screw ND filters on these conversion lenses? Would be nice to have wide-angle with POIS :-)
Does anybody know when these might be hitting the shelves? I've had the 12mm 1.6 on order for ages and I'm looking for something wide for a trip in April..
Thanks
Prolly in May...
I bought and used the inexpensive macro converter from SIOCORE for my 14mm-42mm lens (70 € along with a 0.7 wide angle converter, http://www.siocore.de/konverter/fuer-spiegellose-systemk/weitwinkel-konverter/siocore-37mm-52mm-0-7x-weitwinkel---makro-olympus-pen/a-87987952/ ), and I am satisfied with the results - they certainly look not worse than what is shown in the mynichi.net review. (The Panasonic macro converter is offered for ~100,- € alone.)
@stonebat: Are you sure? According to the Panasonic DMW-GMC1GU spec sheet, the minimum focus distance with the H-H014 pancake is 14cm - and while I cannot cite a spec that is specific for using the SIOLEX macro converter with the H-H014, I am pretty sure that the nearest focus distance I get with that combination is not any further.
We could do a comparison: Let's agree on an object that we both have (like a bank note or alike), and shoot a test picture of it at the closest distance that the auto focus is happy with (at the 14mm end). Shall we? :-)
