MP4 workflow. Mostly on Linux.
  • I have a Panasonic v770 Camcorder.
    It ouputs mov/mp4 files.
    With QT Pro on Windows I can Trim and save without encoding. I'm looking for a similar workflow on Linux(Ubuntu/Mint).
    Some of the linux apps such as Openshot do have mov/mp4 output but restricted to 40 Mb/s.
    Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 850 MiB Duration : 2mn 37s Overall bit rate mode : Variable Overall bit rate : 45.2 Mbps
    Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2mn 37s Bit rate mode : Variable Bit rate : 45.0 Mbps Maximum bit rate : 49.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.362 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
    Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2mn 37s Source duration : 2mn 37s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 4.76 MiB (1%) Source stream size : 4.76 MiB (1%) Language : English Encoded date : UTC 2015-08-15 23:12:14 Tagged date
  • 3 Replies sorted by
  • Depending on your preferences for GUI or command line, try avidemux or mpv with the excerpt plugin.
  • if you really want to edit, you can try blender VSE, it takes many formats as they are, too!
