Panasonic GH3 Notes
New in GH3
New image sensor;
ISO 125 & 25600 for imaging and up to
ISO 6400 for video
MOV (H.264) 50 Mbps (IPB) & 72 Mbps (ALL-I); linear-PCM Audio
+/-5EV control of exposure compensation
Image profile settings (contrast, saturation, sharpness and noise reduction) on a scale of -5 to +5 (against of -2 to +2 on the GH2)
support for Files Exceeding 4Gb
Variable Movie Mode (40%-300%)
Time Code, Time Lapse (start time, interval, #pictures)
Uncompressed data stream to an external recorder via HDMI
φ3.5 mm MIC & Headphones
Support UHS-I memory cards
OLED LCD & EVF
New battery (7.2V, 1860mAh) with CIPA Life-time of about 450 shots + support for external battery-grip
Current GH3 topic on forum:
http://www.personal-view.com/talks/discussion/5344/official-panasonic-gh3-topic-series-3
Panasonic pages about GH3:
Direct manuals links
Firmware Updates:
http://panasonic.jp/support/global/cs/info/dsc/update_gh3.html
GH3 Tips&Tricks
Random Notes
The Electronic (rolling) shutter is limited to maximum ISO1600 and the maximum 1 second shutter speed.
Quick Menu can be customized separately for each mode. C1 to C5 can have individual settings for either still-imaging or video recording.
How to adjust the build-in flash output relative to the metered amount. If you have “Auto Exposure Comp” set to ON in the flash menu, when you have the flash open and are in “A”,”S” or “P” mode (does not work in “M” mode), press the exposure compensation ”+-”-button on top and use the top (index finger) scroll wheel to adjust the power of the flash from -3 to +3 in 1/3 steps. In manual mode, however, the top scroll wheel doesn't change the flash output in any way, and you really do have to delve into a sub-sub-menu.
AFS is single auto focus. Therefore, it does not have to refocus between each burst picture. The burst speed will be fastest in AFS and Manual focus modes. AFF is continuous auto focus but it does not predict motion. AFC is also continuous auto focus but it predicts the motion. Therefore, AFC could be slightly slower than AFF for burst shooting. However, AFC is the better choice for fast motion in a continuous line(i.e: Sports, etc).
gh3-notes/gh3-notes.1362646347.txt.gz · Last modified: 2013/03/07 08:52 by igorek7
