!!UNDER CONSTRUCTION - THIS PAGE IS NOT READY YET!! Contains errors (both factual and formatting) at the moment!!
| Timestamp | Name of Setting | Author alias on Personal-View.com | Video Bitrate 24H mpbs (default 22) | Video Bitrate 24L mpbs (default 16) | Video Bitrate FSH/SH mpbs (default 16) | Video Bitrate FH/H mpbs (default 12) | 720p50 GOP Size (default 24 frames - 1 = Intra/ALL-I) | 720p60 GOP Size (default 30 frames - 1= Intra/ALL-I) | 1080i50 and 1080p24 GOP Size (default 12 frames - 1 = Intra/ALL-I) | 1080i60 GOP Size (default 15 frames - 1 = Intra/ALL-I) | 1080p24 Frame Limit (default 7864320) | 60fps Frame Limit (default 3148873) | 50fps Frame Limit (default 3774873) | 1080p24 High Top Setting (default 21209) | 1080p24 High Bottom Setting (default 14846) | 1080p24 Low Top Setting (default 15589) | 1080p24 Low Bottom Setting (default 10912) | 1080i Top Setting (default 15939) | 1080i Bottom Setting (default 11157) | 720p Top Setting (default 15938) | 720p Bottom Setting (default 11156) | Obsolete (according to author) | Unstable or Experimental (according to author) |
| 9/22/2012 23:34:08 | 240M_GOP1_NOAQ_(PISAF) | @driftwood | 244 | 220 | 122 | 96 | 24 | 30 | 1 | 15 | 5111808 | 3148873 | 3774873 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | Yes | |
| 9/22/2012 22:00:30 | Canis Majoris Night | @driftwood | 176 | 98 | 100.6 | 64 | 3 | 6 | 1 | 1 | 6008080 | 2700224 | 3248288 | 21209 | 14846 | 15589 | 10912 | 98828 | 83179 | 96402 | 75394 | ||
| 9/23/2012 0:50:42 | Crossfire variation no.3 with 'Canis Majoris Night Matrix' plus mjpeg 2k plus Cluster v4 12-15GOP 720p | @driftwood | 176 | 98 | 100.6 | 64 | 12 | 15 | 1 | 1 | 6008086 | 2560224 | 98828 | 83179 | 96402 | ||||||||
| Mysteron Burst | @driftwood | 176 | 77 | 98 | 57 | 3 | 6 | 1 | 1 | 7088080 | 2824224 | 3385683 | 21209 | 14846 | 15589 | 10912 | 98828 | 69179 | 91992 | 64394 | |||
| 9/23/2012 0:45:45 | Crossfire Variation 2 'Canis Green Screen' | @driftwood | 176 | 98 | 95 | 46 | 3 | 3 | 1 | 1 | 6008000 | 2360224 | 3248288 | 168666 | 108000 | 93913 | 92996 | 92492 | 80344 | 86492 | 79344 | ||
| 9/23/2012 0:48:13 | Crossfire var 1 canis majoris gop1 with skintone soft matrix meets cluster gop 3 | @driftwood | 176 | 98 | 84 | 42 | 3 | 3 | 1 | 3 | 6008080 | 2741600 | 3934000 | 21209 | 14846 | 15589 | 10912 | 76492 | 7344 | 76492 | 70344 | ||
| 9/22/2012 22:12:04 | SeAQuake | @driftwood | 166 | 150 | 84 | 70 | 1 | 3 | 1 | 1 | 610080 | 1208873 | 1561592 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | Yes | |
| 9/22/2012 22:24:31 | Quantum v5 | @driftwood | 160 | 100 | 126 | 84 | 1 | 3 | 1 | 3 | 610888 | 148880 | 1580888 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | ||
| Sedna Q20 A | @driftwood | 154 | 77 | 144 | 72 | 3 | 6 | 1 | 1 | 6008080 | 1600000 | 2100000 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | No | ||
| 9/22/2012 21:57:11 | Rocket v3b | @driftwood | 154 | 77 | 144 | 72 | 12 | 15 | 1 | 1 | 6008080 | 1604422 | 2077013 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | No | |
| Orion 4B | @driftwood | 154 | 77 | 144 | 72 | 12 | 15 | 1 | 1 | 6008080 | 16004422 | 2077013 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | No | ||
| 9/22/2012 22:06:59 | Rocket v2 | @driftwood | 154 | 44 | 144 | 36 | 6 | 6 | 1 | 1 | 6008080 | 1680000 | 1960000 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | Yes | |
| Mysteron | @driftwood | 154 | 77 | 98 | 57 | 3 | 6 | 1 | 1 | 6008080 | 2824224 | 3385683 | 21209 | 14846 | 15589 | 10912 | 98828 | 69179 | 91992 | 64394 | |||
| 9/22/2012 23:14:15 | Quantum v9b | @driftwood | 154 | 112 | 80 | 60 | 3 | 3 | 1 | 1 | 608080 | 1413779 | 1687144 | 148463 | 103922 | 109123 | 86384 | 15939 | 11157 | 15938 | 11156 | ||
| 9/22/2012 23:29:42 | Quantum v9 | @driftwood | 154 | 112 | 80 | 60 | 3 | 3 | 1 | 1 | 6128320 | 1413779 | 11687144 | 148463 | 103922 | 109123 | 86384 | 15939 | 11157 | 15938 | 11156 | ||
| 9/22/2012 22:46:13 | Boom! Flat 4s on 24p Intra. Experimental (ignore-non 24P | settings) | @driftwood | 147 | 72 | 95.7 | 57 | 6 | 6 | 1 | 1 | 6060606 | 3683000 | 4676000 | 145854 | 106316 | 70472 | 96517 | 95828 | 69179 | 95992 | 66394 | |
| 9/23/2012 1:09:08 | Natural_standard (stable release 2012-05-09 ) | @bkmcwd | 145 | 118 | 80 | 80 | 6 | 9 | 3 | 3 | 8257536 | 3148873 | 3774873 | 138726 | 97108 | 113956 | 79769 | 71726 | 50208 | 71721 | 50205 | ||
| 9/23/2012 1:46:07 | GOP3ZILLA_SednaAQ1C_standard (2012-05-09) | @bkmcwd | 145 | 118 | 80 | 80 | 6 | 9 | 3 | 3 | 8257536 | 3148873 | 3774873 | 138726 | 97108 | 113956 | 79769 | 71726 | 50208 | 71721 | 50205 | ||
| 9/23/2012 1:47:04 | GOLGOP3-13_lowlight (2012-05-09) | @bkmcwd | 145 | 118 | 80 | 80 | 6 | 9 | 3 | 3 | 8257536 | 3148873 | 3774873 | 138726 | 97108 | 113956 | 79769 | 71726 | 50208 | 71721 | 50205 | ||
| 9/23/2012 1:48:09 | GOP3ZILLA_standard (2012-05-09) | @bkmcwd | 145 | 118 | 80 | 80 | 6 | 9 | 3 | 3 | 8257536 | 3148873 | 3774873 | 138726 | 97108 | 113956 | 79769 | 71726 | 50208 | 71721 | 50205 | ||
| 9/23/2012 1:49:00 | GOLGOP3-13_standard (2012-05-09) | @bkmcwd | 145 | 118 | 80 | 80 | 6 | 9 | 3 | 3 | 8257536 | 3148873 | 3774873 | 138726 | 97108 | 113956 | 79769 | 71726 | 50208 | 71721 | 50205 | ||
| 9/22/2012 23:05:36 | Valkyrie 444 TYPE-ZERO2 Candidate1.2 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' | @bkmcwd | 145 | 118 | 75 | 60 | 6 | 9 | 3 | 3 | 9124000 | 3148873 | 3774873 | 138726 | 97108 | 113956 | 79769 | 71726 | 50208 | 71721 | 50205 | ||
| 9/22/2012 23:11:14 | Quantum v9c | @driftwood | 129.7 | 34.8 | 110 | 55.4 | 1 | 2 | 1 | 1 | 5403016 | 1847296 | 2170880 | 124268 | 86987 | 62132 | 43492 | 15939 | 11157 | 15938 | 11156 | ||
| 9/23/2012 0:01:46 | Sports 10 setting a | @mozes | 112 | 88 | 112 | 88 | 2 | 2 | 1 | 1 | 3640304 | 1609968 | 2050000 | 111566 | 34394 | 62132 | 43492 | 106211 | 74347 | 15938 | 11156 | ||
| SMBU v2 | @driftwood | 100 | 50 | 100 | 50 | 6 | 6 | 1 | 1 | 4166666 | 1637165 | 1997128 | 95830 | 67081 | 47913 | 33539 | 95825 | 67077 | 95825 | 67077 | |||
| Flowmotion 2.02 | @LPowell | 95 | 32.5 | 99 | 55 | 6 | 6 | 3 | 3 | 8000000 | 3750000 | 3750000 | 125000 | 97500 | 52500 | 55000 | 95000 | 95000 | 92500 | 90000 | |||
| Cluster 6 DREWnet (12-15GOP) | @driftwood | 90.8 | 56 | 56 | 35 | 12 | 15 | 12 | 15 | 9470000 | 3233000 | 3476000 | 89854 | 76316 | 65472 | 51517 | 48791 | 47953 | 48590 | 45344 | |||
| 88 EOSHD Unified | @EOSHD | 90 | 45 | 90 | 50 | 24 | 30 | 1 | 1 | 7864320 | 3148873 | 3774873 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | |||
| Cluster 6 Nebular (6GOP) | @driftwood | 88.8 | 48 | 60 | 44 | 6 | 6 | 6 | 6 | 9473200 | 3133000 | 3676000 | 87854 | 79316 | 47472 | 44517 | 56791 | 52953 | 60690 | 54344 | |||
| SMBU v1 | @driftwood | 76 | 66 | 68 | 56 | 1 | 3 | 1 | 1 | 2608808 | 1088808 | 1308088 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | |||
| 9/23/2012 0:39:28 | Pictoris v5b Hybrid CBR | @driftwood | 75 | 40 | 75 | 40 | 6 | 9 | 1 | 1 | 3125000 | 150000 | 180000 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | ||
| 9/23/2012 0:40:21 | Pictoris v5b Hybrid VBR | @driftwood | 75 | 40 | 75 | 40 | 6 | 9 | 1 | 1 | 3125000 | 150000 | 180000 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | ||
| 9/23/2012 0:41:03 | Pictoris v5c Orion VBR | @driftwood | 75 | 40 | 75 | 40 | 6 | 9 | 1 | 1 | 3125000 | 150000 | 180000 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | ||
| 9/23/2012 0:41:15 | Pictoris v5c Orion CBR | @driftwood | 75 | 40 | 75 | 40 | 6 | 9 | 1 | 1 | 3125000 | 150000 | 180000 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | ||
| Cake 2.2 | @balazer | 70 | 50 | 55 | 33 | 8 | 16 | 3 | 3 | 7864320 | 3148873 | 3774873 | 60000 | 55000 | 60000 | 55000 | 45000 | 40000 | 40000 | 35000 | |||
| 9/22/2012 22:38:28 | Sanity 3.1 | @Ralph_B | 66 | 44 | 44 | 32 | 30 | 39 | 12 | 18 | 7864320 | 3621204 | 7549746 | 182397 | 127676 | 134065 | 93843 | 15939 | 11157 | 15938 | 11156 | Yes | |
| EOSHD Vanilla 44 | @EOSHD | 44 | 16 | 44 | 44 | 24 | 30 | 15 | 15 | 7864320 | 3148873 | 3774873 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | |||
| 9/22/2012 23:22:47 | 44M_GOP12_AQ4 | @cbrandin | 44 | 32 | 32 | 24 | 24 | 30 | 12 | 15 | 15728640 | 6297746 | 7549746 | 50903 | 35631 | 37415 | 26188 | 15939 | 11157 | 15938 | 11156 | No | |
| 9/22/2012 22:53:30 | No Adverse Affects | @mpgxsvcd | 42 | 32 | 36 | 24 | 24 | 30 | 12 | 15 | 7864320 | 3148873 | 3774873 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | ||
| Sanity 5 | @Ralph_B | 38 | 29.3 | 44 | 32 | 18 | 18 | 18 | 18 | 7864320 | 3148873 | 2918787 | 38000 | 26600 | 32000 | 22400 | 44000 | 30800 | 44000 | 30800 | |||
| 9/22/2012 22:34:46 | “Default Un-hacked (Firmware 1.1)“ | PANASONIC | 22 | 16 | 16 | 12 | 24 | 30 | 12 | 15 | 7864320 | 3148873 | 3774873 | 21209 | 14846 | 15589 | 10912 | 15939 | 11157 | 15938 | 11156 | No | |
| 9/23/2012 2:47:24 | Cluster_v7_'Apocalypse_Now'_-_6_GOP_Nebula_'444_Sharp2 | @driftwood | 88.8 | 48 | 60 | 44 | 6 | 6 | 6 | 6 | 9473200 | 3933000 | 4676000 | 87854 | 79316 | 47472 | 44517 | 63791 | 52953 | 56690 | 54344 | ||
