To Authors: I suggest not to make one huge page, but to split it in parts and provide illustrations (step by step guides, pictures and videos, you can embed any vimeo or youtube videos)
Just remember to use gh2-hack namespace (all your pages must have gh2-hack:: before them and have /faqs/gh2-hack/my-super-page URL)
GH2 Hacking FAQ
Where can I learn more and get help?
AVCHD encoding bit rates, GOP lengths, quantizer settings, and many more video encoding parameters
“Maximum
ISO limit removal” allows manual
ISO selection of up to 12,800
“All interface languages” lets you select any language via the camera's menu
“30 min limit removal” lets you record longer than 30 minutes on European camera bodies
“PAL↔NTSC Menu” lets you shoot in 25/50 fps, or 30/60 fps for 1080i, 720p, and HBR modes by changing the Setup/Video Out camera menu to PAL or NTSC. After changing the camera's menu, power cycle the camera and format your memory card.
MJPEG resolution settings
Audio encoding bit rate
Microphone gain settings
Known issues and bugs
Using old versions of PTool, when recording video, the LCD will display “Auto” for
ISO, no matter the actual
ISO setting. This is just cosmetic. Your actual
ISO setting is being used.
Videos recorded with some high bit rate settings don't play back in the camera. In some cases, turning the camera off and back on after a playback error will resolve the problem.
If anything unexplained happens after flashing, try resetting the camera. (Menu, Setup, Reset)
There are sporadic reports of a “file number limit exceeded” error message when attempting to record with 64-
GB SDXC cards. Details are sketchy, but it looks like the problem is fixed by reformatting the card, and avoided by recording a short clip after spanning and before turning the camera off. We need more information about this problem.
Misc. stuff
It is recommended that you format your memory card in the camera before recording video, especially if you have deleted any files from the memory card, or if you are using high bit rate PTool settings. Formatting reduces the chances of a memory card write error.
What memory card should I use?
SanDisk Extreme HD Video SDHC 30
MB/s, 16
GB
MB/s, 32
GB
SanDisk Extreme Pro SDXC 95
MB/s, 64
GB
The above cards have proven to be reliable, consistent from card to card, and fast enough for even the most extreme high bit rate PTool settings. Other cards will work at lower bit rates, but they will hardly be worth your trouble to figure that out. Please just buy one of the above SanDisk cards. The 32
GB card, in particular, is a great value. Most PTool settings are designed for the above cards.
discussion
The SanDisk Extreme HD video 30
MB/s cards are apparently being discontinued and replaced with “Extreme HD Video” or just “Extreme” 45
MB/s cards. Early indications are that the new cards are at least as good as the old cards in the GH2.
The 95
MB/sec 64
GB SDXC card allows spanning at the highest possible bit rates, whereas the HD Video cards do not. At somewhat lower bit rates, all of the SanDisk Extreme cards will span.
discussion
64
GB SDXC cards are subject to an occasional “file limit exceeded” error. Please see the Known Issues section.
The SanDisk Extreme Pro 32
GB 95
MB/sec SHDC card is faster than the Extreme HD Video cards, but not as fast as the 64
GB 95
MB/s SDXC card.
Buy from a
SanDisk Authorized Reseller. Fake memory cards are extremely common on eBay, and even on Amazon it's hard to be sure you're getting what's advertised.
SanDisk Extreme Pro 45
MB/sec cards are not recommended.
A few users have reported that new camera bodies wouldn't accept a hacked firmware image. This problem was solved by increasing the “Version increment” PTool parameter. Otherwise, it works to flash firmware images in any order: you can go between hacked and unhacked, v1.0e and v1.1.
Popular tried & tested settings can generally be found in the
settings vault.
Beta settings are new, unproven settings that require testing. They are found in personal-view
discussion threads, where you can also report the results of your testing to the settings developers.
Older settings like CBrandin 44M & 66M, Aquamotion v1, and Reaquainted should work the same with the v1.1 firmware image and the v1.0e firmware image, delivering the same quality and stability for all modes except HBR. See descriptions below.
New settings are being developed and need testing. Visit the discussion forums to find settings from driftwood, bkmcwd, balazer, lpowell, and others.
What follows are merely suggestions of settings that have proven to be reliable and give good or excellent video quality. The state of settings is evolving, and there is not consensus around which settings are best for any particular purpose. If you are interested in eeking out the last bit of video quality, try some beta settings from the forums, and give feedback to their developers.
Higher-than-stock quality 1080/24p, 720p, and 1080i:
Cbrandin 44M: 24H=44 Mbps, 24L=32 Mbps w/ spanning, FSH/SH=32 Mbps, FH/H=24 Mbps
Very high quality Intra 1080/24p and 1080/30p (VMM 80% mode), supports ETC and spanning:
Driftwood Aquamotion v1: 24H and 24L=88 Mbps, 720/60p=60 Mbps, 720/50p=66 Mbps (effective bit rates, due to frame limits). Spans with all SanDisk Extreme cards. Or use a successor, Aquamotion v2
Highest possible quality Intra 1080/24p:
Driftwood Reaquainted: 24H and 24L=146 Mbps (effective bit rate, due to frame limit). Works with all SanDisk Extreme cards, but spans only with the 64
GB 95
MB/s cards. Or use a successor, Aquarius, Aquarius v2, Seaquake, Quantum (beta)
in order of development. Only the most important releases are shown here.
| effective bit rate (24H and 24L) | 66 Mbps | 88 Mbps | 146 Mbps |
| SD cards | most class 10 | SanDisk Extreme | SanDisk Extreme |
| spans | spans | spans | w/ 64-GB 95 MB/s only |
| vmm80% 30p | yes | yes | no |
| ETC | yes | yes | maybe |
| simplest & most reliable | | Aquamotion v1 | Reaquainted |
| higher bit rate 720p | | | Aquarius v2 |
| new encoder settings | SpanMyBitchUp | Aquamotion v2 | Seaquake |
AQ=4; 24L=100 Mbps
encoder settings mostly changed back
much higher bit rate 720p
anamorphic MJPEG with new encoder settings | | | Quantum (betas) |
| | 24H | 24L | 720/60p SH | 720/60p H | 720/50p SH | 720/50p H |
| Driftwood Reaquainted | 146 Mbps (1:4) | 146 Mbps (1:4) | 50 Mbps (1:13) | 35 Mbps (1:19) | 50 Mbps (1:11) | 35 Mbps (1:16) |
| Driftwood Aquamotion v1 | 87 Mbps (1:7) | 87 Mbps (1:7) | 60 Mbps (1:11) | 60 Mbps (1:11) | 66 Mbps (1:8) | 66 Mbps (1:8) |
| Driftwood Quantum beta 5 | 146 Mbps (1:4) | 100 Mbps (1:6) | 89 Mbps (1:7) | 89 Mbps (1:7) | 79 Mbps (1:7) | 79 Mbps (1:7) |
Intra-frame video compression
Most video compression is inter-frame: it exploits similarities between frames so as to achieve better compression efficiency. Intra-frame compression doesn't: it's less efficient, but has more consistent performance, especially for high noise and high motion video. Setting the GOP length to 1 frame means using intra-frame compression.
gh2-hack/gh2-hack-faq.1331377950.txt.gz · Last modified: 2012/03/10 11:12 by balazer
