camera-usage:lighting-faq
Lighting FAQ
 “Hard” or “soft” light characterizes the shadow appearance.
 In general, the larger, more diffused the light source, the softer the light quality.
 There is no rule as to when to use hard or soft light for a shot or scene, and there is no correct or incorrect method.
 While soft light is more forgiving when lighting people, hard light can be used to produce dramatic shadows and attractive lighting effects.
 The primary light source (the key light) generally sets the softness of the light.
 Key, fill, separation (“hair”), and background lights.
 Open-faced and the Fresnel-lensed lights – hard light; softbank, frost – light-softeners
 Hydrargyrum medium-arc iodide (HMI), Light Emitting Diode (LED), and Light Emitting Plasma (LEP) lamps
 Reflections and reflectors
 DIY cheap solutions
 Creating Dimension:
 Lighting is the tool to make a 2D image —the frame projected on a screen—appear three-dimensional. To create a convincing three-dimensional image, the subjects and layers of the scene must be separated from each other. This is accomplished with light or color, creating contrasts of light against dark or dark against light, and by strategic placement of lights and color elements.
 Realistic (“Naturalism”) vs. Unrealistic (“Pictorialism”) lighting
 “Natural” look (interviews, documentaries, etc.) follows the logical positioning of light sources in a scene and is often referred to as motivated lighting. For example, when two people are photographed facing each other in an exterior daylight scene, and one person is backlit, the other person should be in full sunlight.
 stylized “Unrealistic” lighting (fantasy, sci-fi, art-house movies) that bear little resemblance to real life: strong colored lights, heavy shadows, lights coming from strange places, unexpected pools of light, and so on. Pictorialism allows the use of light angles that violate Naturalism’s logic for artistic effect. Though not realistic, both people might be backlit simply because it looks better.
 Faking lighting continuity
 Shoot a scene with several different lighting setups -reset the light for each scene- but make it look consistent. The aim is to make every shot look as good as it can, and create a pleasing visual composition. In some scenes, a character may be lit from completely different directions, or may have different colored lighting on them. If it’s done well, the audience will never notice the lack of continuity.
 Mostly darks shots (“Low-key”)
 Shoot a scene where much of the screen is dark, allowing the audience to focus on one small part of the shot. Low-key lighting enhances depth by using contrasting tones of highlights and shadow. Only a few areas are lit at or above key, resulting in more shadow areas.
 “Night”/ Dark lighting setup in daylight
 Moving lights
 Handheld Lights.
 Silhouettes
 Shadows
                camera-usage/lighting-faq.1380366808.txt.gz · Last modified: 2013/09/28 11:13 by igorek7
