Short high speed capture macro
  • Hi y'all--I need to capture some different kinds of macros in high speed for short duration. The clips only need to bee four or five seconds long. For example, water drops. Does anyone have a recommendation whether burst mode is better than high frame rate for this, and what is the best camera to use. Thanks.
  • 3 Replies sorted by
  • Just check amazon page from time to time and check used prices, can be as low as $440.
  • Thanks Vitaliy--120 fps and 1cm minimum focus should do the trick! It's a bit expensive....
