Panasonic GH5S GH5 S, 4K Video Edition
  • 533 Replies sorted by
  • So now that Gh5s has 4k 60p 8bit....its more than obvious that it can pull 4k 60p 10 bit. More proof on Eva 1 gh5 Gh5s g9 same lsi.
    Hack this camera, anyone. I assure 14 bit video
  • @Brian_Siano
    GH5S is not for everyone. Call it a specialty machine.
    GH5 is better option for general use.
  • i have noticed something peculiar.
    High ISO is a different beast to handle. A7s A7sII GH5s all at high ISO not only and obviously loose dynamic range, but people trend to focus more on mid tones, and clip the highlight with no hesitation. This gives shit image, bad handling of it.
    One must shoot for low light knowing that post would be used to extract the shadow detail at an extent, but clip soooo much the highlights is stupid and bad looking.
    This Japan video speaks for itself.
  • Thanks to @IronFilm and @DrDave for the advice, but I want 4K at 60 fps, and the G85 ain't got it. And I've grown fond of Vlog. So I'm committed to one of the GH5s.
    The video Mike Linn posted, Tokyo Run and Gun, was gorgeous, and made a great case for the GH5s's low light capabilities. But, they used fast Leica lenses, and they shot in areas of Tokyo that are very brightly lit. So I'll be watching for careful comparisons between the GH5 units.
    As for shoots in low-light environments, well, there's Neat Video, and I can rent a GH5s if I get enough lead-time.
  • is almost the same IQ
    If not doing heavy post work, as that is where the 10bit of the GH5 will really shine! Plus GH5 has other features like waveforms.
    But for most people shooting videos with quick turn around, then the G85 will be an almost equally good choice at a much lower price!
    Since I buy a set of cameras
    Always been a strength of Panasonic, that they've not just had the latest topflight cameras which are amazing, but they've always had older/cheaper/lower end cameras which are also pretty darn decent too. Thus you can get a nice A cam / B cam set up on the cheap, or even go nuts with even more cameras (like I used to do with 5x Panasonic cameras for weddings).
  • As @Ironfilm says, the G85 (sort of like the GX85 but in the standard body, and with more dials & features) is almost the same IQ--if I was spending 2 large I would have a tough time choosing between the GH5 body and a G85 with with a Panny 12mm or something along those lines. The bare 5 has some nice pro features though.
    Since I buy a set of cameras, I often look for the cameras like the G85 which is 98 percent of the IQ for half the price. Makes you feel better when you drop it, too. And, hey, the GX85 can be found used for ~$450 and you can hack it for CineD and maybe Vlog--not sure about the Vlog but I did do the CineD. Buttons are fiddly but the IQ is very good. I saw a tiny bit of difference bewteen the GX85 and the G85, but the difference between the G85 and the GH5 is super small. GH5 has all-i and other nifty features.....might be worth the extra cash for that tiny difference, I do recommend just renting one before you buy it. Charge the client or just eat it--knowledge has value.
  • But my concern is when I shoot indoors, with existing light. As we know, the lights we have in our houses aren't really there for shooting video. And when I shoot indoors with existing lights, it's usually kind of muddy and dim. (Sunlight helps, but can't count on that.)
    If you're shooting with fast lenses indoors then you have absolutely nothing to worry about whatsoever. (heck, even a GH2 would be fine!)
    Especially as being indoors you can easily add in your own lights.
    So I'm 95% decided on the old GH5. Here's hoping it gets a price drop in the next month.
    They've already had quite a significant price drop secondhand from launch price. Or if you're really tight on your budget, go for a Panasonic G85/G80 which is quite good too!
  • @DrDave Thanks for the reply. You're not the only one to point out that using Neat Video on GH5 footage brings it closer to the GH5s's performance. (It might get even better if I use the 6K anamorphic setting.) And Kai M on YouTube stresses that he's invested in fast Leica glass, so he's been getting good stuff with the GH5 as it is.
  • @Brian_Siano You have to decide what kind of situations you will be in. On top of that, there just isn't a lot if good info to go on, yet. However, when I ran Neat NR on the 5H sample it looked just a good as the 5s, so it also depends on whether you want to grade your footage.
    Right now, it looks like the IQ of the 5H is the best, and you can grade it. No big reason to go for the 5s unless you shoot in the dark all the time. But then, if you did shoot in the dark, why not go Sony?
    What makes a good video? Good lighting. That's a pretty simple rule.
    You could also buy two G85 cams.
    What will I do? I'll be renting first, then taking a hard look at the IQ and usability. If the 5H is better than the G85, I'll go with that. If the difference is tiny--and it may very well be--I will look further. I won't even rent the 5s until I see some samples that don't have the heavily smeared details. When I compared the G7 with the 4H I preferred the G7 IQ. I did not like the color of either of them. The newer cameras look better in terms of both IQ and color, and IBIS is really handy, People made a big deal about it when it came out, and now some of the same people are saying maybe it isn't a big deal. Well, if you are using some old glass, let me just say it IS a big deal, and it's great with the new glass, as well. If you only shoot 12mm, that's a different story.
  • I'll be buying a camera soon, and between the GH5 and GH5s, it seems that my decision's got one big question. Is the low-light performance of the GH5s worth the extra $400? (Side note: $400 because a GH5 with Vlog is $2100.)
    Lots of people have posted good-looking low-light footage from the GH5s, but it's nearly all outdoor nighttime shots. And they look great. And in the higher ISOs, it's really impressive. But my concern is when I shoot indoors, with existing light. As we know, the lights we have in our houses aren't really there for shooting video. And when I shoot indoors with existing lights, it's usually kind of muddy and dim. (Sunlight helps, but can't count on that.)
    Are there any GH5s tests out there that shoot in a normal room, with no special light, and no excessive sunlight? That'd really help me make up my mind.
  • Turning off IBIS doesn't completely lock the sensor in place. It's still only being held by the IBIS system, which is only so strong. Knocks or impacts or vibration can still make the sensor move. I can see this quite clearly with my G85 with the Meike 6.5mm fisheye- bump the camera hard enough, or mount/hold it on a vibrating surface and you can see the image move (easy to see as you can see the edge of the image circle with the Meike).
  • Oh that is completely hilarious that there was a blackout while discussing the GH5S! Ha
  • Salami slicing product portfolio while minimizing R&D costs to boost overall business margin in a flat or declining market segment.
  • @Vesku it isn't 14 stops.
  • Question about the GH5s. Has it been confirmed or not if we can save our GH5 profile and upload that to the GH5s to have matching settings?
  • 14 stops....
    Why there are no GH5s example videos showing good DR? Only overly bright low light videos with blown highlights.
  • Native iso's when using vlog-l and hlg,are listed as 800 and 5000 at Panasonic's website..
    Also,ex-tele x2.1 for FHD.
    They keep saying 14stops of DR when vlog-l is capable of 12stops..
  • great vid!
  • @kin869 Right. You turn it off if you don't want it. And, believe me, when you have a camera at a distance, like a balcony at an event, you definitely need it. Then you turn it on.
    It is a very useful feature.
  • Our CES Interview
