PR
The Sigma Corporation is pleased to announce that we are going to introduce the SIGMA 24-35mm F2 DG HSM | Art, the world's first large-aperture full-frame wide-angle zoom lens offering F2 brightness throughout the zoom range.
While offering the premier optics of the Art line, this lens covers 24mm, 28mm and 35mm focal lengths. Incredible performance overturns the conventional perception of a zoom lens.
SIGMA was determined to create a zoom lens that offers the same brightness and resolution as a fixed focal length lens: in other words, the highest level of optical performance. The result of this challenge was the SIGMA 18-35mm F1.8 DC HSM | Art, the world’s first zoom to offer a fast F1.8 aperture value throughout the zoom range. Building on this concept, SIGMA has developed the new SIGMA 24-35mm F2 DG HSM | Art for 35mm full frame sensor. It allows photographers to carry one lens to do the work of three fixed focal length lenses, a 24mm, 28mm and 35mm — with F2 brightness and top optical performance. One package delivers flexible functionality and high convenience. In particular, at the 24mm and 35mm focal lengths, this lens offers the performance that is equivalent to that of two prime lenses in the Art line. Instead of changing one high-performance fixed focal length lens for another, simply zoom. This is a new zoom lens for 35mm full frame sensor SLRs that offers the quality of a fixed focal length lens at various angles of view.
The world’s first large-aperture full-frame zoom lens offering a wide open aperture of F2 throughout the zoom range.
A large-diameter zoom lens covering the full frame image sensor. Optical performance equivalent to a fixed focal length lens throughout the entire zoom range. These are the concepts the SIGMA 24-35mm F2 DG HSM embodies. It covers three of the most commonly used prime lenses, 24mm, 28mm and 35mm all in one lens. In order to achieve an attractive bokeh effect at wide aperture, we have developed the world's first zoom lens for the 35mm full frame sensor with an F2 aperture value throughout the zoom range*.Outstanding optical performance of the fixed focal length lenses in SIGMA’s Art line
The SIGMA 24-35mm F2 DG HSM builds on the concept of the SIGMA 18-35mm F1.8 DC HSM | Art, the world’s first zoom lens to offer F1.8 brightness throughout the zoom range. Thanks to the outstanding optical performance, the lens provides the quality of high performance fixed focal length lenses in the Art line.Covering the range of three fixed focal length wide-angle lenses
Delivering excellent functionality and convenience, one lens offers the equivalent quality of three high-performance fixed focal length lenses at F2 brightness: 24mm, 28mm and 35mm. With a minimum focusing distance of 28cm and a maximum magnification ratio of 1:4.4, this lens is suitable for close-up shooting, portraits with an attractive bokeh and deep-focus landscape photography. Photographers have access to the angle of view equivalent to that of three wide-angle lenses without having to switch them. While achieving the desired background effect can be difficult with a conventional wide-angle lens, the large diameter of this lens allows photographers to open the aperture wide and use the shallow focus to achieve stunning results.Incorporating SIGMA’s latest technologies
To realize a large-diameter zoom lens for full frame cameras with F2 brightness, SIGMA designed each and every part with uncompromising care and quality. The lens incorporates large-diameter aspherical lens elements, which require advanced technologies to manufacture, one FLD (“F” Low Dispersion)*2 glass and seven SLD (Special Low Dispersion) glass elements, of which two are aspherical lenses. The advanced optics and optimized lens power distribution minimize spherical aberration, axial chromatic aberration and field curvature, resulting in outstanding optical performance. Even at widest aperture, this lens delivers breathtaking image quality.Convenient handling
The inner focusing system eliminates front lens rotation, enhancing the lens' stability and allowing use of Circular Polarizing filters. This specification is particularly convenient for shooting video.Minimum focusing distance of 28cm
With a minimum focusing distance of 28cm and a maximum magnification ratio of 1:4.4, this lens is excellent for close-up photography.Designed to minimize flare and ghosting
From an early stage in the lens design process, flare and ghosting have been measured to establish an optical design resistant to strong incident light sources such as backlighting. The Super Multi-Layer Coating reduces flare and ghosting and provides sharp and high contrast images even in backlit conditions. The included lens hood can be attached to block out extraneous light, which can have a negative effect on rendering performance.Hyper Sonic Motor ensures High AF Speed
The HSM (Hyper Sonic Motor) ensures a silent, high-speed AF function. By optimizing the AF algorithm, smoother AF is achieved. Also, this lens offers full-time MF by rotating the focus ring of the lens while auto focusing*3. Without changing the AF/MF Focus Mode Switch, it allows faster focus adjustment.Rounded Diaphragm
The 9 blade-rounded diaphragm creates an attractive blur to the out-of-focus areas of the image.Brass bayonet mount
This lens incorporates a brass bayonet mount which has both high accuracy and durability. A special treatment to reinforce its strength is applied to the surface giving it greater strength and making it highly resistant to long-term use.Applicable for the Mount Conversion Service
As an experienced lens manufacturer that has been creating a diverse range of interchangeable lenses, we have started the innovative "Mount Conversion Service*4". With this chargeable service, the mount of your current SIGMA lenses can be changed to another mount of your choice. It gives new life to your favorite lenses when you wish to use them on a different camera body.Art line delivers high-level artistic expression
SIGMA is organizing all its interchangeable lenses into three product lines; Contemporary, Art, and Sports, where each line has a distinctive concept. Designed with a focus on sophisticated optical performance and abundant expressive power, our Art line delivers high-level artistic expression. With the astonishing rendering performance that meets the highest standard, along with landscapes, portraits, still-lifes, close-ups, and general snaps, they are perfect for the kind of photography that unleashes the inner artist. Ideal for studio photography, they offer just as much expressive scope when capturing architecture and starry skies and many other scenes.Customization and flexible adjustment for convenience or a specific purpose is possible. SIGMA USB DOCK that is designed exclusively for the new lens line-ups.
With the optional SIGMA USB DOCK, you can update your lens firmware, adjust focus points and customize Full-time MF function settings as well as the timing to operate the Full-time MF function. By attaching this lens to a SIGMA USB DOCK, which is connected to a computer, the dedicated software "SIGMA Optimization Pro" offers various types of customization and adjustment.Made in Japan
All SIGMA's manufacturing – right down to molds and parts – with a few exceptions, are carried out under a single integrated production system, entirely in Japan. We are now one of the very few manufacturers whose products are solely "made in Japan". We like to think our products are somehow imbued with the essence of our homeland, blessed as it is with clean air and water, and focused, hard-working people. We pride ourselves on the authentic quality of SIGMA products, born of a marriage between highly attuned expertise and intelligent, advanced technology. Our sophisticated products have satisfied professionals and lovers of photography all over the world, because our manufacturing is based on genuine craftsmanship, underpinned by the passion and pride of our experts.
On full-frame cameras, even wide-open, the Sigma 24-35mm produces sharp, very sharp, images. At 24mm ƒ/2.0, we must concede that while the center region is nearly tack-sharp, there is some softness in the corners, which isn't all that surprising to be honest. Stopping down a bit sharpens thing up considerably in the corners, and by ƒ/4.0, things are practically razor sharp across the whole frame.
Sigma Corporation of America, a leading DSLR lens and camera manufacturer, today announced that the new Sigma 24-35mm F2 DG HSM Art lens will become available in late July for the street price of $999.
The 24-35mm F2 DG HSM Art lens is the market’s first full-frame zoom that allows photographers to carry one fast aperture lens that can do the work of three popular fixed focal length lenses – the 24mm, 28mm and 35mm. It includes an optimized autofocus (AF) algorithm for smooth, fast, and accurate focusing, a manual focus (MF) override functionality, and is made of Thermally Stable Composite (TSC) reducing its size and weight.
Built upon the impressive versatility offered by Sigma’s 18-35mm F1.8 DC HSM Art lens, the new 24-35mm continues the Art line tradition of top optical performance that’s comparable to Sigma’s 24mm F1.4 DG HSM Art and 35mm F1.4 DG HSM Art. It offers optimized lens power distribution, and minimizes spherical aberration, axial chromatic aberration and field curvature. The Sigma 24-35mm F2 DG HSM Art lens also features a video-friendly, inner focusing system that eliminates front-lens rotation, enhancing the lens’ stability as well as a Hyper Sonic Motor (HSM) that ensures a silent, high-speed AF function.
Nikon preorder - http://www.adorama.com/SG2435NK.html
I don't really understand why its 24-35. Those are pretty close in focal length where you'd probably want to use a prime instead. Anyone know why they did it?
I believe the idea is to compete with primes, by offering something that gets close to the speed and quality of a prime while maintaining the convenience of a little zoom range...makes sense to me anyway...
Samples
http://www.popphoto.com/sample-image-gallery-sigma-24-35mm-f-2-dg-hsm-art-full-frame-zoom-lens
Another review
http://petapixel.com/2015/07/21/review-sigmas-24-35mm-f2-art-is-like-a-prime-lens-that-zooms/
Available for $879 at http://www.ebay.com/itm/141749723936
Lens is very good wide open across the full frame sensor. Center performance stays at a very high level over the zoom-range. The APS-C/DX-corner is quite contrasty as well but is a bit softer than the center. There is also some gradual deterioration when you zoom towards the long end. The FF/FX-corner is a bit hazy but offers plenty resolution none-the-less up to 31mm but drops a notch in quality at 35mm.
http://www.cameralabs.com/reviews/Sigma_24-35mm_f2_DG_HSM_Art/
New firmware
