Mode | Format | AR | Resolution | i | fps | Bit rate (Mbps) | Notes | |
High Bit Rate | AVCHD | 16:9 | 1920 x 1080 | p | 30 or 25* | 24 | interlaced encoding. Firmware v1.1 | |
24p Cinema | AVCHD | 16:9 | 1920 x 1080 | p | 24 | 24H=24 | 24L=17 | |
Variable Movie Mode | AVCHD | 16:9 | 1920 x 1080 | p | 30,15,12, or 8 | 24H=24 | 24L=17 | no sound. 24 fps playback |
MMM AVCHD(1080i) | AVCHD | 16:9 | 1920 x 1080 | i | 30 or 25* | FSH=17 | FH=13 | |
MMM AVCHD(720p) | AVCHD | 16:9 | 1280 x 720 | p | 60 or 50* | SH=17 | H=13 | |
MMM MJPEG, HD | mov | 16:9 | 1280 x 720 | p | 30 | |||
MMM MJPEG, WVGA | mov | 16:9 | 848 x 480 | p | 30 | |||
MMM MJPEG, VGA | mov | 4:3 | 640 x 480 | p | 30 | |||
MMM MJPEG, QVGA | mov | 4:3 | 320 x 240 | p | 30 |
*30 / 60 fps on NTSC-country cameras; 25 / 50 fps on PAL-country cameras. Selectable on hacked cameras. (see the GH2 Hack FAQ)
†AVCHD frame rates denoted as 24, 30, or 60 fps are actually that value times 1000/1001 - approximately 23.976, 29.970, or 59.940.
copy /b 00000.MTS + 00001.MTS + 00002.MTS new_file.mts
cat 00000.MTS 00001.MTS 00002.MTS >new_file.mts
Format diagonals in millimeters are calculated from the camera apertures. Sensor mode diagonals in millimeters are calculated from the pixel pitch and 16:9 mode resolution. Only combinations of lenses and sensor modes are shown here that yield at least 720p.
GH2 & GH3 | GH2 | GH3 & GH4 | GH4 | BMPCC | BMCC | ||||
720 ETC | 1080 ETC | non-ETC | non-ETC | 3.8k | Cinema 4k | 1080p | 2.4k | ||
(5.51 mm) | (8.26 mm) | (21.41 mm) | (19.83 mm) | (16.52 mm) | (17.36 mm) | (14.32 mm) | (18.13 mm) | ||
1/3” | (6.00 mm) | 108% | 73% | 36% | |||||
1/2” | (8.00 mm) | 97% | 48% | ||||||
2/3” | (11.00 mm) | 133% | 67% | 77% | |||||
1” | (16.00 mm) | 194% | 75% | 81% | 97% | 117% | 88% | ||
4/3” | (22.00 mm) | 103% | 111% | 133% | 127% | 153% | 121% | ||
8 mm | (6.11 mm) | 110% | 74% | 37% | |||||
Super 8 | (7.04 mm) | 128% | 85% | 42% | |||||
16 mm | (12.70 mm) | 154% | 77% | 89% | |||||
Super 16 | (14.55 mm) | 176% | 68% | 73% | 88% | 102% | 80% | ||
Super 35 | (31.11 mm) | 145% | 157% | 188% | 179% | 217% | 172% | ||
APS-C | (28.4 mm) | 133% | 143% | 172% | 164% | 198% | 157% | ||
35 mm FF | (43.23 mm) | 202% | 218% | 262% | 249% | 302% | 238% |
* Different 4/3” formats define image circles varying in diameter from 21.5 to 23 mm. Super 35 is the ANSI Super 35 4:3 silent aperture. APS-C is Nikon DX, which is slightly larger than Sony and Canon APS-C. 35 mm full-frame is 36 x 24 mm. The GH2 and GH3 non-ETC mode sensor areas differ because of the GH2's oversized multi-aspect ratio sensor.
