I am trying to find a suitable way to power a Shure Mic system receiver that is made to be powered with a power adapter ( 110 > 12 ). There are many options for all sizes of 12V batteries on eBay. Any specs from these batteries I should pay attention to ? Are there any chances I fry my receiver ?
Here are the links to a sample battery and my receiver :
My receiver : http://www.shure.com/americas/products/wireless-systems/performance-gear-systems/pg88-dual-channel-diversity-receiver
The power adapter that came with the system is indicating :
INPUT : 120/127V~ , 60Hz 150mA Max. OUTPUT : 12 --- 400mA
@010101 They are at 12.6V full charge. I wouldn't normally let them go below 11.6V, below 10.9V there is the possibility of permanent damage. For any application that would take the batteries low I have a box that uses MOSFETs to disconnect the battery and some LEDs that come on at 2/3 and flash at 1/3 capacity.
I really enjoy flying models so I have a not inconsiderable collection of LiPos. Since some of the big ones are expensive I like to look after them!
@andyharris, Those are 11.1v at full charge, aren't they? I can imagine at the end of the day they drop the voltage down to 8v~7v and your AKG keeps going !!! Hmmm. It's interesting how flexible these devices are these days. How about I get a 4cell 14volt !? It's close enough to 12v hopefully won't kill my receiver and it packs 4000 mA. Thanks for the tip.
I power my AKG wireless system from a 3S 1000mAH lipo. It is easily enough to be able to leave the system on all day (say 0800 to 1700).
I now use a 6S lipo to drive my crane motors, plenty of grunt and very portable.
@bangkng, thanks great thread and info ! I'm not sure why my search didn't find it. In fact I was looking into something similar : http://www.amazon.com/EZOPower-High-capacity-Rechargable-10000mAh-Blackberry/dp/B005XQSN9G
As " dish " being advised and LPowel kindly reminding, the polarity must be matched to OEM device or it could have adverse effects.
@010101 Don't buy that battery. Buy this battery: http://www.amazon.com/gp/product/B0067XMPB6/ref=oh_details_o05_s00_i00
here's the thread for it http://www.personal-view.com/talks/discussion/285/powering-gh2/p11
Great, That's comforting coming from an audio guy. Yes, I soldered my cable with the OEM polarity. I have manage to rig-up a few 10x " AA " batteries holders. Considering the NiMH is only 1.2V the 10x holder would provide a decent 12V. I needed some assurances before plugging it in. LOL
Question is; at the rate of 400mA what would be the life each set !?
I just recently got a Shure Performance Gear wireless lavalier system, and I've been thinking about the same thing. The receiver is rated to take 12-18v, so it should run fine on two rechargeable 9v batteries. There's just enough room for a 9v battery on either side of the box, next to the antennas. However, iI'd need to install a battery power switch on the back panel.
The battery you linked should work fine as well. Just be sure to get the voltage polarity correct!
