I am in the market for a field recorder and am very interested in this unit. Any one have any experience with the DR100mk2 yet? It sells for $299us at Sweetwater, 2 year warranty and free shipping. The Roland R26 sells for $499, 2 year warranty free shipping. The Tascam is a 2 stereo track recorder the Roland is 6 track, 3 stereo.
Hey @digitaldooda,
I currently have the MK11. Can say that it is a VERY good unit. The pre-amps are VERY clean, and the unit is very well made.
Personally I use this for NTG3, and also for recording line out of theatre / music shows. Works very well on both occasions.
Let me know if you have any questions...
You have the new olympus LS-100 in between the Tascam and the roland r26. It seems to be quite good for $ 400.
Could be except it supposedly only captures 2 channels at a time. It cannot record both XLR audio signals and the built-in condenser mic signals at the same time.
You talking about the Olympus...? I am aware of this limitation with the MKII.
Yes. The Olympus LS100. I have not confirmed this as yet. Tascam's literature suggests the DR100MkII can record from both the internal mics in stereo and the XLR/Line inputs at the same time either in stereo with 2 mics or mono fed to both channels. Is this so? The Roland R26 can record to 6 mono channels or 3 stereo according to their add literature. All 4 internals and the XLR/Lines simultaneously. I will report more info on the Olympus as it becomes available.
The DR-100mkii has a major selling point which hasn't been mentioned: S/PDIF input. Prior to the DR-100mkii, the most affordable digital recorder with an S/PDIF input was the Marantz PMD661, which retails for double the price of the Tascam at $600.
Although 2-track recording may be a significant limitation (2 channels are fine for my needs), I think the ability to receive external digital signals outweighs it. I plan to connect a Sound Devices USBPre2 with my DR-100mkii via S/PDIF output, which should allow for degradation-free recording at $950 total (Tascam - $300, SD - $650).
If you like the idea of using a higher end device as the front-end of your recording chain, the DR-100mkii offers incredible value. If you're looking for an all-purpose field recording device, the Oly LS-100 or Roland R-26 look great, and may be better options. (I can't attest to the DR-100mkiis performance as a stand-alone recording solution quite yet, as I'll be using it for the first time on a shoot this weekend.)
