Exposure Latitude Test
                  Firmware Version v1.3
- Improved compatibility with the Panasonic LEICA DG VARIO-SUMMILUX 10-25mm / F1.7 ASPH. (H-X1025) digital interchangeable lens.
- Smooth aperture control is available during video recording.
- [Aperture Ring Increment] has been added with which users can choose the control method of the aperture ring from [SMOOTH] or [1/3EV] in photo shooting.
- Improved compatibility with the Panasonic Battery Grip DMW-BGG1.
- The Fn button on the Battery Grip can be customized in the camera’s custom menu.
https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/index.html
Review in Russian
Panasonic Lumix DC-G95/G90 Review
For 4K video capture DC-G95 uses only a portion of it that's roughly equivalent to a 1" sensor.
The G95 will perform worse when light levels drop, since there's less surface area capturing light compared to cameras that use the full sensor width.
At default settings, the camera is a bit slow to focus on a new subject, though that can be adjusted. The 'wobble' from the DFD autofocus system doesn't make for compelling footage.
https://www.dpreview.com/reviews/panasonic-lumix-dc-g95-g90-review/
Samples
https://www.dpreview.com/sample-galleries/7932302636/panasonic-lumix-dc-g95-g90-sample-gallery/
                  UK deal for 809 GBP
                  In a sense, this is the ultimate skippable camera, because no matter what you want to do with it, there are better choices. There is no single feature that stands out. It's unique in that respect.
I guess there is nobody who is "upgrading" from filming with a G85 to a G95 instead?
Is this chart right ? The GH1 has 11.6 stops dynamic range. Is DR really that bad ?
Each site has its own definition of DR. Also it is PHOTO DR at full resolution.
GH1 is 11.6 stops photo DR also.
https://www.dxomark.com/Cameras/Panasonic/Lumix-DMC-GH1
This may be a better comparison. 7.8 stops but at higher ISO, it is still better than the competition.
Panasonic LUMIX G95 20.3 Megapixel Mirrorless Camera, 12-60mm F3.5-5.6 Micro Four Thirds Lens, 5-Axis Dual I.S. 2, 4K 24p 30p Video, Pre-Installed V-Log, $699
https://www.amazon.com/Panasonic-Megapixel-Mirrorless-Pre-Installed-Touchscreen/dp/B07PZB47HN
That's a very good price--I can't understand why they cropped the video for 4K....
Panasonic Lumix DC-G95 Mirrorles with 12-60mm OIS Lens W/Hoya 58mm UV/CPL Filter for $698
Can also select lot of free bundles, like flash or software.
