Saramonic Blink 500 Wireless System
  • 15 Replies sorted by
  • @IronFilm
    Well, if you take in account real development time and talks I know of - it can be opposite :-) As they have really well though lineup contrary to Rode.
  • Looks like they're following Rode in making a similar product to the Rode GO
  • Sample of usage - note that it is extremely heavy sound compression is used for livestream videos.
    800 x 427 - 55K
  • More details on this little mess of 6 models
    General
    • Frequency: 2.4GHz
    • Gaussian Frequency-Shift Keying (GFSK)
    • RF Frequency Band: 2400 to 2483.5 MHz
    • RF Output Power: 10 mW
    • Signal to Noise Ratio: ≥70dB
    • Audio Gain Control: 11dB, 18dB, 25dB
    • Has 1V Plug-In Power
    • Digital Resolution: 24-bit / 48kHz
    • Frequency Response: 20Hz to 16kHz
    • Max Operating Range: 30m with Obstacles, 50m in Open Area
    • 5 Hours Battery Life
    Blink 500 B1
    • 1 x Blink 500 TX Transmitter with Built-In Microphone and Clip
    • 1 x Blink 500 RX Receiver with Built-In Clip and Camera Shoe-Mount
    • 1 x SR-M1 Omnidirectional Lavalier Microphone
    • 1 x Alligator-Style Lavalier Microphone Clip
    • 1 x Foam Lavalier Windscreen
    • 1 x 1' (30.5 cm) Gold-Plated 3.5mm TRS to TRS Output Cable for Cameras
    • 1 x 1' (30.5 cm) Gold-Plated 3.5mm TRRS to TRRS Output Cable for Smartphones and Tablets
    • 2 x 1' (30.5 cm) Gold-Plated USB-C to USB-A Charging Cables
    • 1 x Pairing Pin
    Blink 500 B2
    • 2 x Blink 500 TX Transmitter with Built-In Microphone and Clip
    • 2 x SR-M1 Omnidirectional Lavalier Microphone
    • 2 x Alligator-Style Lavalier Microphone Clip
    • 2 x Foam Lavalier Windscreen
    • 3 x 1' (30.5 cm) Gold-Plated USB-C to USB-A Charging Cables
    • 1 x Pairing Pin
    Blink 500 B3
    • 1 x Blink 500 RXDi Dual-Receiver with MFi Certified Apple Lightning Connector
    • 1 x 1' (30.5 cm) gold-plated USB-C to USB-A charging cable
    • 1 x Pairing Pin
    Blink 500 B4
    • 2 x 1' (30.5 cm) gold-plated USB-C to USB-A charging cable
    • 1 x Pairing Pin
    Blink 500 B5
    • 1 x Blink 500 RXUC Dual-Receiver with USB-C Connector
    • 1 x Pairing Pin
    Blink 500 B6
    • 2 x Blink 500 RXUC Dual-Receiver with USB-C Connector
    • 1 x Pairing Pin
    539 x 428 - 37K
    559 x 400 - 29K
    547 x 595 - 35K
    595 x 493 - 32K
    579 x 562 - 35K
    570 x 497 - 30K
  • The Saramonic Blink was at BIRTV. It is very small and lightweight. Real competition for the other guys. It includes the microphones on 2 transmitters.
    800 x 388 - 64K
