PR
Melbourne, Australia -- 9 April 2018 -- The latest incarnation of the famous Atomos Ninja line is here. Seven years after the world's most popular portable Apple ProRes recorders burst onto the scene, Atomos is delighted to introduce Ninja V - an all new compact 5.2" 1000nit high bright HDR monitor/recorder with unrivalled advanced features. It has a sleek modern design and weighs just over 11oz (320g) - perfect for mirrorless cameras, DSLRs and gaming.
The perfect small monitor
The near edge-to-edge high bright 5.2 inch screen has a stunning 1000nits of output coupled with an anti-reflection finish - allowing users to clearly see their images even in daylight. Use the color-accurate display with AtomHDR to see in High Dynamic Range, or load creative LUTs at the touch of a button. Ninja V gives you all the critical monitoring tools you need - histogram, false color, peaking, movable 1-1 and 2-1 pixel magnification, waveform, RGB parade, Vector scope, 8ch audio level meters and more!
Perfect 1" thin recorder
Record up to 4Kp60 10-bit video over HDMI 2.0 in edit-ready Apple ProRes or Avid DNxHR direct to affordable SSD drives. The Ninja V's sleek 1" (2.5cm) deep aluminium body is crafted for maximum portability and durability, stealthily attaching to any camera. A truly beautiful design.
HDR perfection every time
The Atom HDR engine ensures perfect exposures when shooting HDR. It delivers a stunning 10+ stops of dynamic range to the LCD in real time from Log/ PQ/HLG camera signals. Playout Log as PQ or HLG to a larger HDR-compatible screen. The display can be calibrated to maintain perfect color accuracy over time.
Long records on affordable storage
Record direct from your camera's sensor and bypass the internal compression quality and recording time limits. It runs from a single Sony-type battery for hours. The new compact AtomX Drive SSD offer robust affordable storage. Available from Angelbird, G-Technology and now also Sony Storage Media Solutions, who join as our newest licensed drive partner. Ninja V also works with Master Caddy II.
Designed for your camera!
Atomos HDMI control protocols allow recording to be automatically triggered, timecode matched and HDR metadata set by a wide variety of cameras. Realtime Log-to-HDR profiles allow users to take away the exposure guesswork in HDR production.
Audio inputs
Audio can be input directly from the camera digitally via HDMI, or fed in analogue via a stereo 3.5mm line/mic socket - especially useful for cameras that do not have a mic input.
Endless open expansion!
Enhance the capabilities of the Ninja V through the ingenious modular expansion slot breaking out connectivity for high speed video, audio and power. Expansion modules will dock onto the battery slot of the unit and offer advanced features such as continuous power modules. Atomos and third party accessories will be available in the future.
Atomos CEO Jeromy Young explains: "Ninja V is the result of years of development and expertise. It combines the best of what we do at Atomos and squeezes it into one small box. It sits stealthily on your mirrorless camera, yet it is packed with power. It's what everyone wants! Small, sleek 5" and future proofed with AtomOS and the modular expansion slot - at $695 it's a no brainer. Put simply, Ninja V is the most versatile outdoor monitor and portable ProRes recorder ever. We can't wait to see how it unlocks creativity for our users."
Come and see Ninja V for yourself at NAB 2018, Atomos booth C9425.
The market really needed a small recorder capable of recording 4K. But...,
with no SDI, there is no RAW output recording with any existing cameras. It is useless for the Sony FS700R and FS5 (I or II) in gaining 4K 120P and 60P, which one can do using the 7" Inferno.
The benefits for existing cameras: this will enable owners of the GH5 and GH5S to record 4K 60P in 10bit, and all of those many Sony RX0 owners to record 4K 30P in 10bit. Otherwise, for most owners of mirrorless cameras it permits just higher bitrates at 8bit 422, for which almost no one sees a significant difference.
If one needs just a nice HDR screen, one is better off with a model without the recorder to get an even more compact form with better battery life.
And while I am in a pessimistic mood: the fact that it uses a new form of storage that is not a standard means it is likely that (1) this product will not be available for a while and (2) the storage will be expensive. Currently the Inferno uses standard SSD drives (which are still expensive).
Am I going to get one - yes.
The PR says it works with "Master Caddy II" which seems to be a thing that you put an SSD into. B&H is selling 5-packs of them for $30. https://www.bhphotovideo.com/c/product/1123989-REG/atomos_atomcad112_master_caddy_ii_5.html
So at least storage doesn't seem like storage would be super expensive - just the price of an SSD plus $6.
Aside from GH5 owners, this could be nice for owners of the original A7s (like me). There's almost no difference in its ability to work in low light vs the A7s II, but can only record 4k externally. I currently use a PIX-e5 which weighs 16 ounces. A 11 ounce alternative might be nice - though not nice enough that I'm going to go spend another $700. :)
I want one of these, now! So much better on a hand-held rig.
@eaststoomuchjam Yes, I did just see the Ninja V works with the same caddies as the other Atomos units too. It will just stick out some from the body compared to the new shape.
I wonder what the "modular expansion unit" will bring - hopefully SDI!
I've been waiting for this it solves many of the problems with any brand that has recording limits among other things.
This would have been perfect to have paired with a cheap secondhand FS700 (something I keep on debating with myself to get), but without SDI it can't do FS raw :-/
Fingers crossed there is an Atomos Samurai V in the future.
So would I buy this and finally get 4K for my A7s (mk1) or get an A6300 for just 100$ more?
I’ll lose lowlight and supposibly dynamic range but gain better color science and better autofocus for my two Sony lenses. With a speed booster for my Canon FDs I’ll have basically same field of view.
Hm...
And if you buy the A6300, you'd be able to do two-camera setups instead of just one. :)
I could see there being a cable to connect the expansion port to proprietary LCD connector on EVA1 to get video, audio, and power and maybe for the ProRes Raw. Seeing as how they have several promo photos of this with the GH5 and Atomos CEO said to push and scream at camera manufacturers to add raw out on their hdmi cameras, I wonder if the hardware on the GH5 and GH5s would allow raw out over HDMI. @Vitaliy_Kiselev do you know if this is physically possibly with just a firmware update?
@eatstoomuchjam Good point :-)
@markr041 you referenced RX0 (I assume you mean all revisions of RX100) as having 10 bit output over HDMI. Could you link to independent confirmation? I don't dispute it, it will be a factor in deciding to buy a RX100 VA, which records 420 8bit internally.
I didn't know RX0 was a thing. Looking it up now. Edit: Q&A on Amazon says RX0 HDMI output is 8bit 422. I have no use for the form factor anyway, and the lens starts at f/4.
BTW is there a compact camera (any brand) with a built-in zoom lens that has 10bit output?
That "answer" on Amazon was not from the manufacturer, unlike some other answers, but quoted from a private blog site.
10bit 422 via HDMI on the Atomos site, 420 8bit internal. And it was tested. It is a specialized camera indeed. No other Sony compact camera for sure has 10bit output.
Hmm. We're off-topic wrt to the thread, but since we're there already: what's the use case for RX0? It's not an action cam (needs gimbal). Starts at f/4 so outside cam but watch the lighting (has ND attachment?).
Underwater cam maybe? I read the IQ is awesome compared to Hero6, but since it doesn't have internal stabilization they don't compare well. I might care for it if I understand the use case over a RX100.
Edit: since it syncs in a fleet of RX0's I guess it's meant for fly-on-the-wall shots, in tight corners or rough environs. It won't replace but complement a RX100, just like RX100 would complement my PXW-Z90.
There is a changeable faceplate with a standard screw on thread precisely for ND filters or polarizers or close-up filters. I forget the mm, but it's a standard size. Comes with lens shade and uv filter (for protection if not using a filter).
Mounted on a small gimbal, attached to the tiny Ninja V via HDMI and you have stabilized 4K 422 10bit video (Slog2 for HDR) in a small rig!
@radikalfilm It doesn't have a built-in zoom lens, but you can change the lenses on the Black Magic Micro Studio Camera 4K which is very small and it outputs 4-bit 4:2:2. You could pair it with something like the Olympus 14-42mm power zoom which is also tiny (and it only like $200). It's not the best lens in the universe, but it's probably sufficient for anything you'd be using such a small camera to shoot.
@eatstoomuchjam that micro studio thing has no built-in recording! You can't use it without an external recorder (which implies some sort of rig), so it has none of the form factor advantages RX0 has.
@markr041 I gather you're an owner. I spent some time today watching reviews. It has some strong points to be sure, but I'll wait for Mk2. Two fails as is: 1. No internal 4K 2. Overheating
If Sony follows up and fixes those, I can see myself taking a couple of them on set. This is a tight quarters camera, for shots where the A-cam doesn't fit or you don't want to risk damaging it.
Your gimbal+RX0+Ninja V setup makes no sense for me, just so you get 422 10bit 4K. Not worth the hassle. You still need to plug in sound, so it becomes a frankenrig. This is not meant as A-cam! Get a PXW-Z90 for A-cam (same sensor), or wait for the BM Pocket 4K if you must have 10bit.
@radikalfilm Well, the RX0 only records 4:2:0 1080p internally and you were looking at that as well so I thought you were planning to use an external recorder. Anyway, I was answering this question of your with my response:
That's why I mentioned it doesn't have a zoom lens, but that you can get a cheap one with sufficient quality.
If you want a compact camera of that size that can record 4K internally and can handle it being 4:2:0, then you're already on the right track with the RX100. Otherwise, the Z-Cam can do it, but it's still a headache to use.
Yes I'd much rather have the Micro Cinema Camera instead! Even though "only" HD
Caleb got a Ninja V to mess with finally. Seems like good pairing for the Z6. It's really not much more expensive than a good monitor to be able to record 4K60 10-bit Prores.
Atomos Press Release: Shipping and New Modules
IBC 2018: Atomos Ninja V ready to ship, innovative new AtomX Sync and AtomX Ethernet/NDI modules announced
Melbourne, Australia – 13 September 2018 – Atomos is delighted to announce that the highly anticipated Ninja V 4k HDR monitor/recorder is in mass production and on schedule to reach stores before the end of the month – fulfilling our commitment to deliver in Q3. The all new 5" 4kp60 HDR monitor recorder has unrivalled features in a sleek, compact and extremely light form factor that is perfect for mirrorless cameras, DSLRs and gaming consoles.
The 10-bit mirrorless revolution The timing of shipment coincides with the launch of several new mirrorless cameras with 4k 10-bit HDMI output and Log gammas that partner perfectly with the Ninja V. The new Canon EOS R, Nikon Z6 and Z7 and Fujifilm X-T3 now join the Panasonic GH5 and GH5S in taking full advantage of the Ninja V 4k 10-bit 422 recording to Apple ProRes or Avid DNxHR. The results from the Ninja V and these cameras are extraordinary, with billions of shades of color for smooth gradients and better grading in all NLEs.
New AtomX modules under $199 – the most flexible ecosystem in Pro Video Modularity is at the heart of the Ninja V with a bi-directional high-speed expansion port breaking out connectivity for I/O of video, audio and power. Atomos created AtomX to ensure users could adapt and connect to any legacy or future wireless or wired video standard. The expansion system offers endless scalability and is demonstrated by the first of many modules - the AtomX Ethernet/NDI® $199 and the AtomX Sync $149 announced today. These dock into the AtomX port and instantly add important features like NDI® over ethernet and Wireless Sync and Bluetooth control to the Ninja V.
Atomos are proud to expand their close partner program with Newtek for the NDI® module and Timecode Systems for Wireless and Bluetooth sync module.
The AtomX Ethernet/NDI module has a wired ethernet (1 GigE) connector that makes it possible to deliver live broadcast-grade video over IP networks. Newtek’s NDI technology harnesses this - allowing for simple installation and control of multi-camera networks, replacing traditional SDI cabling. The AtomX Ethernet/NDI module has NDI input and output with encode, decode, control and sync, allowing Ninja V users to transmit, distribute or receive and monitor NDI from any NDI source. Simply power on the Ninja V with AtomX Ethernet/NDI module installed, plug in your network cable, and your source will be automatically discovered on the NDI network ready for production.
The AtomX Sync module brings professional wireless timecode, genlock and Bluetooth control to Ninja V, perfect for enhancing DSLRs, mirrorless cameras or game recordings. You can sync and/or control literally thousands of Ninja V units equipped with AtomX Sync modules on the same network at ranges of up to 300m. Multi-cam shoots have never been so easy. AtomX modules bring broadcast level standards to any HDMI camera or source, making it easy to integrate large sensor consumer cameras easily into traditional live productions. AtomX Sync has a built-in battery extender that allows for continuous power when swapping batteries, ensuring uninterrupted operation of the Ninja V during a shoot.
