Specifications
Preorder:
...as well as a pop-up viewfinder and fast 24-70mm lens ! Finally, something to wear a hole in my jeans again !
XAVC is marketing term made by Sony, it is not some new compression :-)
but it is higher bitrate recording at 50Mbps. I'm hoping it also has 70/120p as well , just like the cx900
I seem to remember at time when they added an XS to VCD and suddenly everyone thought it was something to talk about. I didn't pick this name for nothing.
Some previews links:
This camera could be a very good aerial video platform! the mk1 and MK2 were quite good already. What's the weigth? my LX7 does not fit on my phantom 1 but if this one is under 250gr... maybe^^
It will probably be identical to the RX10, which our team owned and returned. Excellent in good light, and bad in dim. Color fall off, especially in browns, in low light. Spectacular resolution. DR not so much. Microblocking will be better due to codec change,
nice but I will stay at the RXII. Absolutely enough for point n shoot, making of and private pictures & videos. 50mbit/s sound seductive but for professional shots I will use a professional camera ;) I also experienced 70mm (equivalent) as too short.
                  Any external audio input? Don't see any.
First for the RX100 series is a 5-axis stabilisation system, which should help to ensure steadier movies are created.
The RX100 III's other improvements of note include the option to record Full HD video footage at up to 50Mbps, or up to 100fps in the XAVC S format. Dual video recording will also be appreciated by those who’d like to record high quality AVCHD/XAVC S footage alongside a smaller MP4 format file that’s easier to share.
http://www.trustedreviews.com/sony-rx100-iii_Digital-Camera_review
I thought at first the 720/120p mode wasn't in xavc-s but I was wrong . And the dual mp4/xavc-s recording is quite useful.
http://www.sony.net/Products/di/en-gb/products/c3jk/specifications.html?contentsTop=1
...and let's not forget the hdmi out as well. IMHO the rxlll clicks all of the boxes. I only wished they would have developed a higher res sweep panorma and taken the lens to 90mm. Pretty small "con" list. It will be perfect for the new handheld 2-axis gimbles.
@babypanda Guess you can't have it all
Still it would be nice is there was an audio input. Deliberately crippled camera.
