First off: this is probably a hardware error:
Dark halo-ing on the left(?) of bright objects!
UPDATE! This is caused by i.Dynamic settings. Turn OFF to avoid these artifacts!
AVCHD 50p ISO 160 Shutter 1/50 Photo Style: Natural: -5,0,0,-5 WB: Cloudy First clip: Olympus 45mm f1.8 @f1.8 Second clip: Lumix 14-140mm, 14mm@ f4
MPEG 50p export straight from Premiere
oscillian - is this halo visable in camera on the rear screen when you view the footage - or is it something that has been induced onto he image in post due to processing in Premiere
try trouble shooting this to see where the issue is occuring
I had an issue with my G6 it had a dead pixel cluster on the sensor so its had to be returned for a replacement new body - Im now awaiting this to arrive
Here's a quick similar test with my G6 in 50p. Portrait all dialed down except sharpness at 0. No haloing like @oscillian 's - would seem to be a faulty copy so hopefully you can change it in. Original file.
https://mega.co.nz/#!FxATwR4T!N71vuws5jpKSjPD5B5JSwARbye1MzqJ72g_lwgPZeTw
@oscillian yup. It’s more pronounced when you keep the paper over the sofa. I would still try higher contrast adjustments in-camera though. Probably some in camera magic going on. Natural light leak seems different than this.
Seeing as this video was recorded on my camera, I did a similar test to oscillian to see if this 'haloing' is as apparent indoors as his was.
First I used 50p, 1/100, Profile Standard, Iso 3200 and to my naked eye, it wasn't visible. But when I instead used 160 shutter it became slightly visible in poor light.
Edit: Scratch that, I just performed another test with a white piece of paper against a brown wooden table and the shadowing was very visible, in 24p (1/80) and 50p (1/160). A lamp illuminated the area I was recording and when I moved the crinkly paper against the upper left of the table (where the light created a slight glowing reflection) the 'halo/shadowing' became very obvious. So I seem to have the same problem as Oscillian, And it seems to be occurring only on the left of bright objects.
can you post your sample on vimeo and youtube ...this helps to get their attention !
wow...the etc mode clip shows just how bad this is . I recommend people comment on the vimeo page itself. That clip should convince the ceo of panasonic himself .....there's a problem groundcontrol ! thanks amigo
Another problem is color inconsistency in JPEGs, which I noticed in timelapse use. On full manual settings with all "i.Something" features off, sequential JPEGs have slightly different color balance, even though WB is clearly on manual.
Will post examples as soon as I have time to do a test in controlled environment. Also will attempt the halo/shadow test on my unit.
Ok, I think I found the problem. The dark shadow is caused by i.Dynamic feature. If set to other than Off it creates the dark shadow to the left. Examples: i.Dynamic Auto (50p ETC-mode, Natural -5,0,0,-5) AVCHD straight from camera
Examples: i.Dynamic Off (50p ETC-mode, Natural -5,0,0,-5) AVCHD straight from cameraIt looks like you're new here. If you want to get involved, click one of these buttons!
