Hi. I want to now if there is any chance to the hack makes cappable the usb composite video out during the recording.
I use the 2011 model of this: http://www.ebay.ca/itm/2012-New-Model-HDMI-Composite-S-Video-Converter-HDCP-analog-AV-RCA-splitter-/270951799146?pt=LH_DefaultDomain_0&hash=item3f15fc596a
It takes 5v DC to power it, and the system I was using had a spare 12v output, so a simple 12v-5v step-down transformer and a 2.1 x 5.5mm Male plug connector and a wee bit of soldering, and I was good to go.
It seems like the unit can take more than 5v and operate just fine, so I might have been able to feed it the full 12v and skip the transformer, but spending $5 on that to ensure the longevity of my $40 converter seemed like a wise investment.
Can't start shooting video after switch on camera/after stand by mode -there is a sign "please wait" when press record.Need to wait about 2-3 minutes or press rec. button rapidly to start.Please advise how to fix this. GH2 hacked Aquamotion(latest version) SD card Sandisk Extreme Pro 64Gb 10 class (made a format - doesn't help)
@EjiK I've never encountered that issue before. Here are a few things to try to narrow the cause of the issue (also note that there are many newer hacked settings by the same author that are generally considered better as well as some by other authors as well).
Try putting the camera on a tripod and loading both the hacked and un-hacked settings to shoot the exact same thing. Note if you get the same error.
If the same error happens in both cases, try shooting with a different memory card to rule a defective or malfunctioning one. If the error only happens with Aquamotion, try loading a different hack (such as Driftwood's SMBU v1 or v2, Flowmotion 2.02 or Sanity 5) to see if the same thing happens.
thanks for solution seems the problem was in SD card - I format it again - problem has gone.(please wait only indicates when you've just swich On a camera)
moved
Just recently started getting a problem with audio that GH2 records. Some shots the audio is normal, but some shots the audio is juddery/stuttery/choppy and you cant make out what anyone is saying. Using Apocalypse Boom v1 with Sandisk 64GB Extreme Pro cards, and ive gone out many times with it where audio was just fine. The last few times though, I'm getting that juddery/stuttery audio. Anybody know what this is? Did I hit a button and change something in menu? Any solutions?
something to help on the Lumix GH2 evf to well with the sun?
Vitaliy_Kiselev
14398
stonebat
3639
driftwood
3083
