I further modified my Smoothee to where I'm happy with the performance now. As it's very lightweight, there's still an issue with windy days, but for some specific shots I'm really happy that I can chuck this little baby in a carry-on bag or backpack.
Sorry about the audio, my phone rang during the shoot.
Looks great! Can you show us a photo of this rig... maybe a couple from different angles? Thanks in advance.
wow! nice house too!
Don't be so optimistic. I am sure @Rambo will be able to make same footage if you give him camera with 100mm lens, rock and do it during huge earthquake.
It's a simple addition of extra weight on a pivot similar to what others have done. But the trick is getting a perfectly balance setup to eliminate the side to side tilt you see on rigs like this, it has to be balanced so there is a slow drop time from 90 degrees to vertical with NO over-swing pendulum at the bottom, it just stops dead. The gymbal on the SteadiCam Smoothee is identical to the SteadiCam Merlin2 and being lighter makes for even less friction. Setup like this, my full operating concentration is on eliminating rotation horizontally by anticipating the direction it will try to rotate when I make speed changes or turn corners by countering in the opposite direction. This way i don't need to guide it with an extra hand or touch the gymbal collar with my fingers and cause tilts (only the handle is held).
On big heavy rigs you can guide the rotation with the other hand, i believe on small rigs you shouldn't because they are sensitive to touch due to low mass. ""YMMV""
@vicharris, yes Panny DMW-GWC1
@dandof, the extension is meant to be adjustable sideways to balance/level the rig in addition to the adjustable stage under the camera. The wing nut secures it. Also it swings into the main rig for transportation. It's best not to have the extension too long or too far away from under the gymbal. Ideally with these small rigs, camera, gymbal and bottom weight should be aligned vertically or close enough.
I can balance this rig perfectly in under a minute with the GF2 or GoPro, not tried the GH2 yet.
Vitaliy_Kiselev
13836
stonebat
3609
driftwood
3028
