24-105mm F4 Macro O.I.S. LUMIX S FF Lens
    734 x 534 - 51K
    800 x 560 - 60K
  • 2 Replies sorted by
  • PR
    The LUMIX S 24-105mm F4 MACRO O.I.S. is a versatile standard zoom lens covering wide-angle to medium-telephoto. It assures high descriptive performance across the entire zoom range. In addition to its versatile use with a wide and long zoom range, the LUMIX S 24-105mm F4 MACRO O.I.S. enables 0.5x macro shooting with a minimum focusing distance of 0.3m. Panasonic LUMIX’s image stabilization system 5-Axis Dual I.S. (Image Stabilizer) 2*1 can be used with LUMIX S 24-105mm F4 MACRO O.I.S. for the first time as a lens of full-frame mirrorless camera system, never to miss the photo opportunity.
    The lens unit comprises 16 lenses in 13 groups and the use of 2 aspherical lenses and 2 ED (Extra-low Dispersion) lenses effectively suppresses chromatic aberration and achieves high resolution.
    The O.I.S. (Optical Image Stabilizer) in the lens effectively compensates for the hand-shake movement, making it easy to shoot even without a tripod or in low-lit situations. Complying with the camera’s Body I.S., the 5-Axis Dual I.S. 21 makes it possible to use 6-stop slower shutter speed2. The high-precision linear motor achieves sensor drive at a maximum speed of 480 fps for fast auto focusing. The LUMIX S 24-105mm F4 MACRO O.I.S. also excels in video recording performance with a mechanism that suppresses focus breathing, which was a fatal problem of all interchangeable lenses designed for still image photography.
    The refined design of the LUMIX S Series provides high operability as a tool for professionals. The rugged dust/splash-resistant*3 design withstand use under harsh conditions even in 10 degrees below zero for high mobility. In addition, a fluorine coating on the front element repel water and oil and prevent them from attaching. The filter diameter is 77mm, with a 9-blade circular aperture diaphragm.
